Dave Kegel
Here's another link that covers sway bar combinations, but I'm not sure how much it applies to a car with coilovers: http://www.panix.com/~awinbow/sho/suspension.html
I recently drove two Gen2s back to back on the track. One with 24/26 bars and poly bushings front and rear, the other with 24/26 and rubber front bushings/poly rear. The car with poly/poly had noticably more understeer, as you would expect. So, running the 24mm front bar with rubber bushings seems like a good alternative to switching to the 22mm bar, at least on a fairly high speed track.
Like Mark mentioned, for a track car, yoy can actually get by without sway bars if you have stiff enough springs. Mike Courtney's track car had no sway bars, if I remember correctly. As for 700 lbs springs... I personally can't see how the SHO-specific Koni's could even keep up with that kind of a spring rate. I guess they'd last a while at full stiff, but I wouldn't think it would be streetable.
Dave Kegel
<small>[ June 06, 2003, 06:02 PM: Message edited by: Dave Kegel ]</small>
Dave Kegel
