What pump are ya'll using?
LJRuddy
Pop lock n drop
Poaceae fields
I am bleeding my brakes (too many triple digit quick stops :woo-hoo: ) and I am using the manual vac pump from Harbor Freight. It seems to hold plenty of vacuum but when I open the bleeder valve, all I get a 20:1 ratio of air:fluid. I then took the pump off and did the manual method (pumping the brake pedal) and I got zero air coming out of the valve. So now I am shopping for a good quality brake bleeder that I can depend on when I don't have any help.
So, what cha'll using to pump your fluid? :naughty:
gmorrell
Never been a noob...
Colorado Springs, CO
Why don't you get a Motive pressure bleeder?
http://store.motiveproducts.com/sha...StoreType=BtoC&Count1=87734401&Count2=4874825
The Motive is a slightly pressurized bottle full of fresh brake fluid is connected to the master cylinder reservoir, then all you do is put a bleeder bottle on each caliper and open the bleeder fitting. No sucking, no pumping the pedal, no running back and forth between the front and rear of the car. Supremely easy...
SHO_DOODmorrris
Owner & Fanatic
Alberta
yeah, we have a pump at our school shop but it sux... and its a MAC one. like ken said but i dont even use a hose lol just a rag usually does fine!
LJRuddy
Pop lock n drop
Poaceae fields
Which pump is compatible with the Taurus SHO?
I also have a 98 GT Mustang that I would need this to fit. :salute:
1995SHO9
FLEES ARE COMIN
Carlisle PA
I was scared to click on this at first. I thought you might have been having some personal problems stiffler...
gmorrell
It's either the Ford round two tab or three tab, I can't remember. Pop the cap off your MC reservoir and have a look.
Motive should be able to tell you which cap you need for your 98 GT.
