munkee
Too busy...
I still haven't found whats causing the problem on my 90 mtx. After replacing the front head and the cam sensor last weekend, the backfire is gone but the engine still shakes, misses, and my coolant gauge still doesn't work. I have switched to motorcraft plugs and wires and I am positive that they are gapped and routed correctly and the brand new timing belt is also on correctly. The cps is gapped correctly and I am not getting any fault codes. I am going to be replacing the rod bearings this weekend but I don't think that has anything to do with it. I don't really notice a knock and no oil pressure light but the motor has 210,000 on it and the previous owner wasn't too good with oil changes. I have looked through the wiring and didn't find anything amiss but my temp gauge isn't working even though the gauge and the sender is fine. I am wondering if maybe something happened to a wiring harness. Has anyone had a problem before that could shed some light on this? I could definitely use some ideas if you have any. It really sounds like its missing due to a timing problem but I have gone over everything timing related. Thanks for all of the previous help, hopefully I can get it fixed this weekend.
