What do you do for an oil change?
SuperG
Houston, TX
For those of you who change your own oil, do you simply drain, refill, and change the oil filter?
Please tell me the steps you take...and forgive the ignorance on my part...
How much oil does a 93 ATX need, by the way?
shojuan
sunny San Juan Bautista,
SuperG:
That's about it. No need to make it more complicated than it is.
Rick
Tommy's SHO
SHO Member #535
Montréal, Quebec - Canada
Use 5 quarts of Castrol GTX 10w-30 and the Motorcraft FL-400S oil filter. You'll also need a 14mm socket or box wrench to unscrew the oil plug.
Oh yea, to raise the front of the vehicle drive your car up some ramps, or do what I do, use the jack to raise the vehicle and secure it with jack stands before you get under it. :)
jthomas68
Area 51
Just change the order.Drain,change filter(i fill the filter about 1/2 way before i install it),refill.After running the car for a minute or so,shut it off,wait a few more minutes,check the level again.Add if necessary.
91 SHOplus
Sholess 4 Now
North Jersey
Oil capicity should be 5 qts.
However, some of us use oversized filters that may require xtra oil to read correctly....
BlackOnBlackATX
Dutchess County, NY
Word of warning, where Ford placed the filter housing allows for a drippy mess when your removing it :( if youre going to do this yourself from now on, take some of that money youre saving and order the relocation kit from Jegs (i think, or maybe its summit). Youll be happy you did, i know mine is on its way for christmas thumbs_u
<small>[ December 11, 2002, 11:03 AM: Message edited by: BlackOnBlackATX ]</small>
SuperG
Houston, TX
Wow! Thanks for the quick responses! I also heard to protect the starter from drips...I just replaced my starter and the mechanic said it was covered in oil...
I'll look into the relocation kit...
You can make a shield to catch most of the oil from the filter using a plastic 2-liter beverage bottle and a sharp knife. Helps keep the mess off the starter.
Tommy's SHO
SHO Member #535
Has anyone changed there oil while there engine was cold?
I have done it once and changing the oil filter wasn't as big as a mess(few drops of oil that came off the oil filter housing) as it is when changing the oil when the engine is hot.
TVSHO
Charlotte, NC
I change it when the engine is cold. Makes it a litle bit easier.
As for original question...one minor bit of caution. Always make sure the oil filter gasket stays on the filter when removing and doesn't stick to the engine. Sounds simple enough but I've seen people miss this and cost them big time later!
Tom
'94 ATX
Put a light coating of oil on the new gasket of the new oil filter before installing and do not over tighten it. Read the instructions on the filter.
RTStabler51:
Um Ford Recommends 5w30....
...for temperatures below 100F. For temperatures above 0F, the 10W-30 is optionally recommended. In the Great White North, the 5W-30 is probably a better choice in the colder months, but for us southerners, who never see temperatures below 0F, the 10W-30 would be the oil of choice year 'round.
doucebag
Campbellford ON, Canada
How much and how hard is it to install the relocation oil filter?
just wondering because it sounds like somethind worth while.....
Do you guys suggest using an additive, like slick 50 or dura-****?
91 plus
removed cone and cut air intake box
Marccus
California
NASA did a big study on oil additives and concluded that they aren't worth dpg ****.
I use an oversize filter, Motorcraft Racing Filter FL1A, or K&N HP-3001 (rqted for 12 - 16 gpm). You can also use the oversize Fram racing filter HP-1,l which I don't think is as well made.
I need 5.5 quarts of 10W-30, usually Castrol or Valvoline non-synthetic.
The K&N ovrsize is still only rated for 12 to 16 gpm.
What surprises me is the small filter Ford requires as stock for an oil pump that can put out 20 gpm at redline. Granted you're not runnning this puppy at redline, but when you run it hard, that filter just seems to be too small.
Also, be careful on fitting and line sizes when relocating the filter. Most spin-on adapters have 1/2" ports and most kits use -10 AN hose. The pressure drop through a 1/2" port or fitting is HUGE at 20 gpm. (Refer to the Parker Fittings website and their graphs of fitting pressure drop as a function of oil flow; Parker has a division that makes fittings and hoses for Formula 1 racing cars and a division that makes fittings and hosefor the aerospace industry).
Same for a -10 AN hose. You can undo the convenience of relocating the filter by reducing the oil flow to the engine (or increasing unfiltered oil to the engine) when the oil pump relief valve pops (oil filter bypass valve opens).
You can find spin on adapter plates that have 5/8" ports; 3/4" would be best. And I wouldn't use less than -12 AN hose (as also recommended to me by the boys at thinkauto.com, a UK firm who specializes in oil coolers, etc.).
I just don't think it is worth it to relocate the oil filter and incur all that pressure drop which may reduce oil to the engine or increase the amount of unfiltered oil to the engine.
Now if you want to install an oil cooler or a bypass oil filter, which filters a slip stream of the oil to 1-2 micron levels, then you're OK.
I'm installiing a remote mounted bypass filter. Studies indicate the the oil stays clean and doesn't change color. Trucks have run on NTZ byapss filters for hundreds of thousands of miles on the SAME oil. NO OIL CHANGE!
Ford is now installing these types of filters on their automatic transmissions because the allowances for particles in an automatic transmission are becoming tighter and tighter.
Check out the NTZ website.
I'm installing it because I'm just curious to see how clean the oil stays and how long the additive package is maintained with oil analysis.
I definitely don't think there is any need for a bypass oil filter, but my curiosity is driving me to install it.
Curiosity killed the cat ---
But satisfaction brough him back!
