What do you do for an oil change?
93nighthawk
Mitchell, SD
I usually do it to a warm engine (let it run for like five minutes), it takes for ever for cold oil to come out of the crank case, plus this gets more of the dirt out of the engine because the oil is more fluidic than slugidic. Otherwise same recomendations as everyone else.
Eric
SuperG
Houston, TX
I don't really have a flat drivway...which way should I face the car? Front end down slope or up slope?
quick91
SHO LAND
Do none of you guys take the cap off when you drain the oil? If not, you should because the oil drains better and it releses that vaccum in the system.
quick91
SHO LAND
I would make damn sure it wasn't too steep first but put the front end up slope or whatever POINTING UPHILL and invest in some wheel chocks that just may save your life.
BlackOnBlackATX
Dutchess County, NY
hey doucebag, the relocation filter is supposed to be like a 20 minute mod. if i recall its less than 40 bucks. maybe even around 25-30. one end screws into the filter housing and then you bolt the other end somewhere and voila! or so it seems.....
