What do I need to take apart fuel rails.
60kmaintenance
U.S.A.
What gaskets etc do I need.... I have to replace that stupid vacuum hose that broke off. What gaskets do I need? I have all the valve cover and intake gaskets, not a big deal. But I imagine I need some thing for the fuel rails. Any information on torque specs?
SHOtimer
#2910
Santa Clarita, Ca
All you will need for the fuel rails is a new set of O-rings. Each injector has three rubber seals - RCM sells a good set. Their are four bolts holding down the fuel rail - I forget the torque but their is one. It is a very tedious job to install the rail, make sure the O-rings seat, and deal with the wiring harness.
Good luck.
Doug
shobroooo
