Hubes
well i just got back from ntb where i dished out 310$ for an alignment and 2 new tires. this should be a testimonial for all those that delay getting an alignment. in march i bought 2 new tires and had them put on w/o an alignment because i needed to get the parts to do it. 2 weeks ago i got 2 new rear endlinks, i also put on the adjustable camber plates too (moog brand), all new struts and all new springs and a driver's side ball joint, and 3 months prior i got new front endlinks. after having them all installed, my steering had to be turned 45 degrees to the left to make my car go straight. what i though would be like a $60 charge turned out to be a $310 charge. apparently, not having the aligment killed my new tires. the guy showed me the wear on the inner side and on the passenger side it was almost showing the steel belts. the previous tires were continental tourings and now i have two yokohamas and the car drives great. the yokohams were 30$ more expensive than the contintentals which they don;t sell anymore because the guy said they are junk.
let my loss be your gain...always have your car aligned and do not put it off liek i did bvecause it will cost you more money in the long run.
next to tackle:
front motor mount, exhaust rattle, ac clutch regapped, and fog light prob.
next to tackle:
