well... im done.
SASHO91
Zoom Zoom
San Antonio,TX
Yall remeber my post about putting locktite on your PP bolts???
I should have listened to my own advice.... which i was... i bought the locktite a couple days ago, and i was going to do it either today or tomorrow.
well... tomorrow never came.
I was driving over to a buddies house.. Coming up on to a on ramp, i accidently cut a guy off. He went nuts!! Riding my a$$, and coming into my lane, then we started to cut me off... so i said, forget this... dropped to third and punched it... he was trying to stay with me, so i didnt let off. went into 4th, and left him behind... but then, all of a sudden.... BOOOOOM!!!!! along with clanking noises and whatnot....
the engine reved to 7k and died. ( i think i know why) and, all i saw behind me was a cloud of smoke.... so now im coasting down from 100+ mph, with no PS or hardley any brakes... i put my hazards on, and im slowly coming to a stop. Then, the guy that was f'in with me, throws me the finger?!?!? Im just ****** completly off at this point...
So i come to a complete stop... I pull the Fire ext. out, as there was alot of smoke... pop the hood, and no fire... ok, thats better. I start sniffing and smell this mix of Tranny fluid, and coolant.... there were 3 things that poped into my head almost immedialty when i heard that boom. 1 st was, Diff. 2nd, was the bottom end ( thought about the RB's) 3rd, a headgasket..
Not one of those was correct..
I get under the car, and look at the oil pan, still there. (dont ask why i looked at it... ) then i looked over to the tranny.. i could see the aluminum plate sheild that goes between the tranny and motor, hanging there, bent to crap... then i look towards the radiator.. to find that the PS cooler was hit forward, and hit the radiator ( the new 2-3 week old radiator) and abviously it punctured it. then i think how the **** did that happen... i look alittle closer, with the little tiny lite that i had, and see the starter sitting on the front of the subframe...
I get back up, and look down into the motor trans area... and i shine the light down there. and i can see Flywheel, and clutch.. well, what is left of it...
another thing i noticed when i poped the hood, was the motor was leaning towards the left side (driver)... i knew then that something was major.
I called my buddy up, and we towed it back to my house last night. All of this in 40* weather, at 12am, on the side of a highway... allthough those were the least of my worries...
On the way home i started thinking about the motor, as i KNOW the trans is toast. I remebered that it reved up before it died.. Now this is what i need help with.. could the reason the motor died, was from the ground for the starter not connected, well the whole starter not connected?? or is there a chance that the motor is gone too? What im afriad of, is that the motor caught 1st or 2nd, when all that happened, and just reved it to crap... but i cant really remeber if I was on the gas or not when it happened... but i think i was though.
As it stands now, just from my little inspection, it looks like im going to need: new tranny, new clutch, new flywheel, ring gear, radiator, starter, maybe the pass carrier shaft, maybe a rod shifter, and some more little things as well....
I am so.....
**** i cant even find the words to describe it...
******, dosent even cover half of it...
I am totally lost.. and i dont even want to tear into the car... im afraid that i blew the motor as well.
I would have been happier blowing the diff...
oh, for some that dont know what happend. basically the clutch exploded...
i think this is my sign to call it quits with the sho.
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
:frown: :eek: uhhh..... :oogle: OMG, now how the heck do you think it all happened.... starter decided to engage itself... then throw itself around the engine bay?
hmmmm, well when it went all shoboom like... did it **** harshly or front wheels lock up at all ... if it did throw itself into 1st or 2nd? Hmmm. did it just cut out? did it rev down? I know you probably don't want to think about that night again, but gotta kinda figure out how stuff happened.
I'm sorry man, I think I'd be kicking something right now :frown:
SASHO91
Zoom Zoom
San Antonio,TX
what i think happened, was the PP bolts back out, and the clutch decided it wanted out...
took everything in its way out... thats how the starter got to the subframe...
Im actually afriad to go look at the car right now, as it is daylight... :(
the car didnt **** at all.. at those speeds it just tears anything up that is in its way(holding it back)...
It just basically blew up...
i cant rember if it rev down, but i think did. But it only dropped to 5k, then cut out.. but like i said, it happened all so fast...
i think i will go take a look at it though... i need to...
jedhead
westminster,ca
I'm glad now that I used new bolts, washers and hi-temp red loctite on my pressure plate.
Bob
jedhead
westminster,ca
When my tranny locked up I was only going 40mph. What freaked me was that when I pushed in the clutch the tires were still locked up. It unlocked and I coasted to a stop. I found out my diff bearing was destroyed. I hope to be done with the rebuild next week.
Bob
SASHO91
Zoom Zoom
San Antonio,TX
well, i went out to take a closer look...
i got to pull out a few pieces of tranny, and a piece of the PP.
I think the starter is fine though.... :nut: it just broke off part off the tranny... so techincally its still bolted to the tranny... :nut:
i might be able to salvage the radiator.
But as for tearing into her, that fun is going to have to wait till this weekend.
i think i can get a hold of a trans. but, im not too sure...
what really worries me the most is the input shaft on the tranny. I cant tell if it tore up the crank any...
im not even sure if im going to tear into her... im so discussted with this car right now... and honestly, i dought its going to go away.
i even got on to autotrader.com to look for another car.... and it didnt even phase me.
SeanMc
NoMoSHO
Geez man, that sucks. It's a good thing you weren't hurt! I'd probably go buy another car, and then after some time when you feel the time is right, buy another SHO :biggrin:.
DVJ38
Hartford, CT and Worc, MA
Good luck
Wow, dude I'm so sorry that had to happen. I would be rip ****! I would not want to even rip into the car after all that. If you are though, just start taking the broken pieces off and look at everything that needs to be, or might need to be replaced. Then decide if it is time to scrap it and move on, or start repairing. I also like the GTPs! I plan on moving on some day, but I hope it's because I want to move up, not just switch cars because horrible things keep happening. This car sure has ****** many people over. I am taking out a loan soon just so I can get my car into good shape. Read sig (lots of things...)
Good luck with whatever route you decide to go. Just make sure there is a good forum for the possible new car.
SHO#7
Cincinnati
I am sorry to hear of your misfortune. But, you did encourage me to buy new pressure plate bolts, and locktite.
Good luck. You will get her back together.
Mike
ohfosho
ontario SHOwner
ontario, canada
yeah get a new car! just get an ****** gt! they are great lil things...especially with gas prices. also keep the SHO and work on it a lil as you go.
