pascofan92
I've got a 94 Atx 3.2. I noticed this problem when i go up hills, really lay on the gas, or travel at high speeds on the interstate.When i'm in any of these situations my rev meter will go up accoridingly to the pressure of the gas pedal but when it reaches a limit it will go down quickly a few revs and then back up again until its at a normal interval.Now when i lay on the gas to go up a hill or pass cars the meter goes up accordingly and then it goes up some more and then down and back up as if the revs are trying to push the car faster.I feel the car going a little faster foward as the rev meter goes up.I'm getting ready to have my 60k done this weekend.I hope this solves this.Could this be anything to do with a valve lash that needs to be done? Or is it because of a little cylindrical actuator that sits bechind the intake and opens up at certain ranges could be bad?when i had my car serviced by a ford master mechanic he said that little cylinder should be replaced or you will "experience a loss in horse power".I'm lost And I really need help.Thanks
Alaric
Alaric
