Weird OCCASIONAL alignment pull
Yamaha V6
SHO Enthusiast
Rhode Island
Ok, here's the scoop.
Make a right turn (like at an intersection), and the car pulls to the right afterwards. Make a similar left turn, and the car goes dead nuts straight (until you turn right again).
Tightened up the SFB's today also, and it's still doing it.
A guy at A-Zone mentioned Ford racks that "burp" air on the right side, causing it to bind up a little bit. Anyone heard of this? This is a new on to me.
Oh, and today I discovered that both CV Boots are torn about 2" long & all the grease has gone on hiatus. It's A Wonderful (SHO) Life...
LaTechSHO
Louisiana
had a similar sorta situation... check your strut rod bushings.... thats what my problem was.... the bushing on the passenger side at the frame was gone to ****...... causing serious movement of the strut rod under stress.... of course mine did it under acceleration as well.... good luck
Louis
RStalveyARFF
too many shos
Georgetown, MA
what have you checked? Are your rack nuts tight? tie rod ends? strut nuts at the tower secure? How's the alignment printout look? If caster is real positive on one side, it will want to stay turning that way until you pull it out. My caster is so high that I don't have PS return (but great response). As mentioned, strut rod bushings, as well as swaybar endlinks, strut bearing, etc.
twr
whoohoo
half-way there, I think.
Strut bearings binding?? I have heard that some of the SS strut bearings binding up, but never a stocker.
<small>[ September 09, 2002, 04:56 PM: Message edited by: twrsho ]</small>
