shoon
cliTaurus
Have been following some of tompumped's threads, and he discovered his diff pins broke and it was causing a rattling that would occur in neutral. The only way the noise would go away is if either the clutch was pressed in, or the shifter was pushed forward towards any gear. I have the exact same symptoms except I have a wavetrac so I doubt its a diff pin issue. Does anyone else with a wavetrac have slight rattling in neutral? and.. is this normal?
