Water Pump Problem. Leaking coolant Help
carlsho
Montreal
I finally saw where my 89 sho was leaking antifreeze coolant. Between the crankshaft pulley and the waterpump pulley right ontop where you see a measure 0-10 for adjustement. There is like a gasket on the bottom of the water pump. Should I purchase the waterpump with the gasket and 2 orings or just gasket. Is this my problem. Please help
Cohiba
Denver, CO USA
Yeah, the gaskets are probably bad... I would recommend replacing the whole pump if it's never been replaced before. You have to remove the pump to replace the gaskets anyway...
SHOemup
Dalton, PA
if you replace the pump, i would also suggest you replace the belts, timing belt, lower radiator hose, CPS also since you're going to be ripping apart the entire right side of the engine bay.
