By "new" do you mean a new Motorcraft pump, a new aftermarket pump, or a new "remanufactured" pump?
A reman will only include the pump to housing gasket and you should buy the Fel-Pro ES70425 kit (under $5.00 at RockAuto) which also includes the pump housing to block o-ring and the two crossover tube o-rings as well as the gasket for the intake pipe from the lower radiator hose.
The Motorcraft will have the pump housing to block o-ring, but IIRC only one crossover tube o-ring (the pump to housing gasket comes pre-installed).
Aftermarket new pumps I think are hit or miss as to what o-rings they will include, but are usually assembled just like the Motorcraft pump.
In any case, having the Fel-Pro water pump kit mentioned above on hand is always a good idea regardless of which pump you buy IMHO; it's $5.00 worth of extra insurance should you accidently damage a gasket or o-ring
