water leaking inside of my car.
kit352
holland, ma
noticed the other day the sho was getting a bit stinky. felt around and felt moisture on the rug on the drivers side. looked but i didnt see anything. all windows and sunroof were shut. rained the next day and went to check on the car and the drivers side floor is soaked. put a hose all over the car ro see if i could spot the leak but no chance. i took off the the wipers and cowling but it was pretty dry in their. didnt see any place to leak. anyone got any ideas?
shobote
Naperville, IL
Probably the drivers door weatherstip is needing to be sealed; I had that as well on another car; pick up some weatherstrip sealant, clean it up with rubbing alcohol and apply; should be good to go.
You do need to get at the mold though, as it will not only stink, but cause health problems; remove the carpet, steam clean.
bacernate
97 MONEY PIT
Denver, Colorado
Take it to a glass shop, they should be able to use a smoke machine to find the leak.
It isn't coolant is it?
Take your cowl off and make sure the black plastic shield is on correctly for the cabin air filter, if it's not on right it definately can leak into the car. The side flap usually gets broken off or lays flat instead of being bent over the side of the filter. It's a pain to get in correctly so people break them.
