water leakage into passenger side!!
c_olcott
Lynn, Ma
not too long ago i pulled a small plug ,on the lower front passenger side, out of the door jam. It is slightly above and to the right of the power window/speakers cable plug. I ran my subwoofer power cable through that hole and now i found out after the latest batch of rain we had that water leaked onto my car. Almost 2"!!! It almost dry now (about another hour of a heat gun should do it) and i just wated to be sure that that is where the water could have leaked in from. This was really the first big rain that has come through since i've had the car. If anyone has an idea of other places to look if it leaks or an easy place to run my power cable please let me know
thanks
Bizzy
Did you have the subframe plate nut recall done? It requires that holes be drilled in your floorboard to allow access to the top of the bolt. I don't think it would be possible for this to happen...but it might be worth checking anyway.
I also don't think that hole would allow that much rain to drain into your car. You may want to pour some water over the door area and watch to see where it goes. That's about all I can offer.
