violent shaking
kasza87
RED89SHO
Staten Island N.Y.
my 89 sho has a front end problem. wheels are wearing unevenly when im on the highway the front end shakes when i drive a certain speed usually over 60mph and it also shakes when i slow down. what coukls this be?
AREA 91
PA SHO SHOP
Area 91
Check tire pressure
Check wheel balance
wheel bearings
strut rods
subframe mounts
jmpSHO
Massachusetts
First of all sounds like you need an alignment but in order to do that I would check to make sure the front end is tight. I would jack up both sides and see if you have any play in the wheels and it also sounds like you made need your tires balenced.
B.Benard02
Texas
I had the same prob with a old LX I had. It turned out 2 be the wheel bearings.
Do you hear any grinding sounds coming from the front wheels?
crystizel
