hawkeye18
Sorta cares
Does the transmission rev match for you on downshifts? If not.. yeah if you've ever driven a standard and you were rolling at 25 down a hill and put it in first your gonna get an effect much like that..
Indeed. Putting any automatic into first (actually, any car at all, really) at 25mph without making an attempt at rev-matching will produce exactly the symptoms you describe. As soon as the clutches engage, the engine is basically doing a backwards neutral bomb. The reason it took a second to shift was likely that the ECU was preparing the transmission for such a violent maneuver, which takes a little bit of time.
Stop putting it into first at 25 (especially going down a hill already) unless you are going to blip the throttle to get the revs closer in the middle of the shift (something I used to do in the [race] trans tune on my 94 frequently).
