vibration and noise when turning and leting clutch out
91 SHO Black
OH FO SHO
Vancouver WA.
when at a stop i'll dry turnthe wheel and start to go (let out the clutch) and sometimes it'll do this odd vibraty noise.and i can feel it in the stiering wheel. what the **** is it.
CademiaX
What's an SHO?
Utah
Its your flux capacitor!! Ok kidding...
I have the issue on my 95, I will be doing my subframe bushings soon. I am going to drop the subframe and the engine out tho, so I guess soon will be longer then I think.
Ill let you know if it solves the issue.
mike25
92 sho
south carolina
Mine make's a light clunk when im turning left it only does it when im moving i can turn the wheel stopped and it dosent do it.anyone know what this could be?
Does it make the standard "clacking" of a worn CV joint when you apply any gas in a tight turn? That would be a CV joint. If so, just get a remanufactured CV halfshaft for about $60 with a lifetime warranty. Much easier and cleaner to replace than a CV jont boot.
mike25
92 sho
south carolina
I drove it today and it does it sometime's when stopped but mostly when moving while im turning left or right. when i start turning it will pop once.and once when i straighten the wheel. sometimes it doesent do it at all.
mike25
92 sho
south carolina
I drove it today and it does it sometime's when stopped but mostly when moving while im turning left or right. when i start turning it will pop once.and once when i straighten the wheel. U can feel it pop through the steering wheel.sometimes it doesent do it at all.
Nomospm
