RJ-92
I pulled the valve covers on my 3.2 lastnight to begin installing the cams and.. WOAH!!
holy varnish! The motor only has about 80K on it but the amount and color of the heads has me a lil concerned. I am replacing the bearings so that's not an issue, but I am a lil worried about the rings. I'm gonna run a compression test on it, but could the acuracy of the test be skewed by carbon build up on a motor that showd this kind of varnish.
I am assuming this type of build-up would be attributed to using cheap oil and not changing it enough. I was going to use the existing 3.2 oil pump but now I'm not sure if that's a good idea.
Any thoughts would be appreciated.
