Valve stem seal replacement tips
Racer X
SHO Pilot, Retired
Connecticut
Use the SHO engine tool kit, and a magnet stick to grab the valve keepers. You'll drive yourself insane trying to use needle nose pliers.
jmpSHO2nd
Massachusetts
Mrhappytuzi
Divorced from SHOs
Delafield, Wisconsin
Ehh.. the most time consuming thing i'd ever done. If its burning oil bad just take the heads off and have someone put new valve guides in.
sho4life
midwest
how long did it take? im getting sick of adding oil all the time to my car. plus its robbing horsepower.
yamahaSHO
E85 whore
Arkansas
This will save HOURS off of removing and replacing valve stem seals.
jmpSHO2nd
Massachusetts
After removing everything from the car it took me 5-6 hours to replace the valve stem seals. Like YamahaSHO said definately invest in the right tools or you will spend a lot longer to get the job done. Some people have had trouble with getting the keepers back in place but I didn't have much trouble with those except the one I lost. I found that if you try to install both keepers at the same time, they go back in a lot smoother and faster.
http://doxinh.com/danh-muc/do-lot-nhap-ngoai/ http://doxinh.com/danh-muc/do-lot-nhap-ngoai/do-lot-korea/ Do lot thailand Do boi http://doxinh.vn/danh-muc/do-dung-cho-be/dung-cu-tap-an/ Cho thue studio Do boi tre em
