valve cover
Gen3
DFW, Texas
well I've already done the upper (the first thing I did) and I'm scared of the lower I want to change the bearings too (like really soon) but I don't want to screw up by alignment and have to spend another $150 to get it fixed (again :/) so I want to get everything else together that requires me to drop the subframe before doing that Tranny is going out and I want to change the struts too...(but with my luck something is going to blow up before I get ready)
Gen3
DFW, Texas
in the tutorial thingy, it said to take the subframe off for the rod bearing, and the part about the struts, is it'll screw the alignment...lower 60k...I'm just afraid of it (I'll probably end up doing it anyway) if I can manage them all without dropping the subframe then it'll be sooner than later (especially the bearing)
RAYJAY
WHO ME ?
UNION DALE PA
to do the rod bearings you only have to drop the starter ,y-pipe and oil pan (the 2 bolt by trans are a *****) easy one day job .....
Jeff
crystizel
