Vacuum leak
1993BlackSHO
Arlington, TX
OK the engine is in and running but I think I have a vacuum leak. I had to pull off the intake to change the wiring harness from mine to the 95 motor. So I think something did not seal right or is not plugged in.
Checked codes and KOEO passed and the KOER test gave me an O2 lean code (dont remember the number).
I think I can hear it and is sounds like it is comming from the passengers side of the intake. It looks like it is seated to the block, and I cant see any tubes unplugged. The secondars are closing, so it must not be too severe. But the car is definately lacking in power. I could hear the secondarys open at 4k but the power just was not there.
Phoenix
SHOHOLIC
QC , Canada
I use brake cleaner , have the engine running , and spray where you think there's a leak. You will find it when the engine will rev weird.
Carb cleaner can work to , or propane with a little hose.
