The largest line on the bottom of the throttle body, that points toward the passenger side of the engine, is a crankcase breather line. The second, smaller one comes from the front valve cover to the top of the throttle body. The only other vacuum line is the small line from the charcoal purge canister to the top of the TB. The other two connections to the TB are coolant lines. One of these routes to the IAC valve spacer and doesn't need to be removed unless you are removing the TB from the intake. The other coolant line hides well under the intake and routes from the IAC spacer to the cooling system and completes the coolant path to the intake.
