V8 rack & pinion question
JATO
Norman, OK
First off I don't have an SHO. I drive an '06 Vulcan. I post on TCCA under the same handle. I have a couple question regarding the steering rack on the Gen3 SHO. Does the V8's rack have a faster ration and fewer turns lock to lock than my Vulcan's? If that is the case, can it be swapped into my car?
Thank you for listening to the babblings of a lesser Bull owner.
Ratio is the same at 16:1, turns to lock is a bit lower 2.48 (3.4L) vs 2.75 (3.0L).
The SHO has a higher flow pumping rate and higher minimum pressures but if they work with the Gen 2 PS pump I wound not think that is a problem.
