Upper 60K results....
40BelowSummer
Puerto Rico
Well I did my upper 60K recently and just went on a trip to Salt Lake City. i replaced plugs\wires\O2 sensors\intake gaskets\ect sensor, Before this stuff I was running lean and getting 14 mpg.
I filled up and reset the trip odometer before I went on the trip, when I was ready to head back home I filled up again 8.086 gallons and when I did this my trip odometer read 249.6 miles. So thats about 29.6 mpg in my ATX, wow I was surprised. I even used the secondaries a bit.
So if your getting bad fuel mileage and need a 60K, do it.
:thumb:
Bizzy
I need wires, but have newer plugs and 25k on the current valve lash, and I pulled off 27.5mpg with the AC blasting on a recent 250 mile trip. Played around a little from 60-110 a few times maxing out 3rd.
Dr. Tweak
Mad Scientist
Northern Vermont
:thumb:
Nice! :D
You said those tools are on the way back, right?
Petersho1
IL
I think you are one of member "Lean Club" right? We had the some problem. I just found that fuel injectors needs cleaning in mine. Maybe it will work for you. I run lots of time BT before it shows somethink.
40BelowSummer
Puerto Rico
well i think my 60k fixed it, but not sure. On my way back from Salt Lake I had a CE light a bunch of times. I checked codes but nothing?? I am going to try again. I hope I fixed it. I will run a bunch of fuel injector cleaner in my gas too.
hope you get it fixed
thatSHOguy101
