pbgsho
I am in the process of doing an upper 130k on my 90 SHO. I have removed the hoses going to the heater core and noticed that the metal pipe from the heater core has what appears to be a swaged aluminum fitting connecting a short rubber hose that attaches to the block. Believe I have read that this fitting is prone to leak so I wondered if it is advisable to cut the fitting off and replace it with a rubber hose and clamps?
Never will understand why Ford used these bastard hose clamps since I had to cut four of them off.
Hopefully when I remove the rear passenger side intake hold down the rear valve cover will come out. This must be a two person job since I have not been able to hold wiring and other lines out of the way while removing the valve cover.
In addition to checking the valve lash ,replacing plugs and wires, water and vacuum lines, thermostat, valve cover gaskets and plug well seals what other items should I consider replacing?
Once it is running I will look at doing front main seal, cam seals, CPS and timing belt. Being somewhat conservative I don't want to change too much at one time since, if there are problems, it makes diagnostics somewhat more difficult
Thanks,
pbgsho
Thanks,
pbgsho
