Universal Clutch Aligning Tool
DHMag
Free At Last
InCahoots, Texas
most clutch sets come with the alignment tool, so buying one would be a waste of money. when i did my clutch, i ended up keeping my alignment tool just in case. if you find you do need one, you can borrow mine.
EDIT: that tool says for workbench assembly. it wouldnt be an essential tool to own, at least for the SHO.
<small>[ August 03, 2003, 10:37 AM: Message edited by: DHMag ]</small>
Off Road SHO
Moderator
I have several that I have picked up over the years, but when ever I need a new size, I just make it. I use a 1/2" wooden dowel that I just wrap tape around to get the right thickness for the pilot hole and the disc spline (usually two different thicknesses).
**Helpful hint. Drill a hole through the end of the dowel that will be sticking out and tie a stout string onto the dowel. Makes for easy removal once you tighten the pressure plate bolts.
Tom the Tightwad
<small>[ August 03, 2003, 11:28 AM: Message edited by: Off Road SHO ]</small>
bmytych
