Yamaha V6:
Gee Mike, does Paul Nimz know about this? wink
I think Paul should try this mod.
First of all, for those calling BS. This is on several cars right now, has been tested on the track, and yields
much better results than under drive pulleys.
Please, know a little about what you are talking about before you call BS. Do you know how an alternator works, or underdrive pullies for that matter? Underdrive pullies release some of the power it takes to spin the accessories by using larger pulleys, which in turn makes them easier to spin, but comes at the expense of a slower spinning accessory, which, at idle, could mean problems. Luckily it hasn't been that big of a problem on the SHOs.
The more power the car requires, the harder it is to spin the alternator. By releasing load on the alternator, it basically free wheels at WOT, thus freeing up a lot more than an underdrive pulley ever could.
There is more of a load on the battery, but certainly nothing it can't handle. Lets say, by chance, you want to accelerate from 0 - 100mph. That takes you about 16 seconds we'll say, unless you're Fred.
That 16 seconds of no alternator is still a fraction of the load it takes to start your car. If you're like me you are constantly at WOT... Not a problem. I was driving a 91 MTX the other day when the alternator belt snapped on the expressway. We were still 15 minutes from my friends house, but we made it back fine, without a charge. Not only that, but we listened to the radio, and the next day when we went to getthe belt, we started the car up and drove it to Autozone.
Get my point? Basically there are no worries of problems with charging. It's better to use a deep discharge, but it's definetly not required.
I have installed this on 1 GL, I will be installing another one on a 95 ATX SHO tomorrow, and another Thursday on a 91 MTX.
The VAK responds quicker than the ECM at cutting the A/C. There are no variable, such as there are with the A/C. Once you reach a position on the throttle, it's off, as well as the cooling fan.
Whether the product works or not is not a question, whether or not you want to believe it does, is the question.
<small>[ January 07, 2003, 07:36 PM: Message edited by: Mikeys_Taurus ]</small>
