Two issues need some help
Metal Thunder
CA
I dropped the y pipe today to try and track down a continuing oil leak and discovered that the oil pan is missing the two front bolts that straddle the crankshaft.
I would like to know if anyone knows the part number for this, or where I can get some new bolts.
Second issue, is there seems to be some sort of cover on the front of the engine that is called main oil galley or something like that but i can't find a gasket for that or the oil pump in any parts listing.
Can anyone help clear that up?
sho2see
sho2see
Baltimore, MD
Bolts you could go to the junkyard and pull off of another sho oil pan. Or maybe try homedepot but I don't know if those bolts would work in this situation.
SHOGUN88
1994 MTX
Langley, BC Canada
Which gasket do you mean for the oil pump? You can get it here at http://shonutperformance.com/
