turn singnals dont work
bi0c0mp
Sh0Bi0s
Brooker,Fla
Hi we just bought a 1994 ford tarus sho love it only thing wrong turn signals dont work dont come on in or outside tried looking for a fuse cant find any bad ones at all unless i am missing one or somebody knows why else they wont work..would be a great help..thanks in advance..for your help
93SHO'nOFF
And you are...Who???
Lehigh Valley,PA
Do hazard lights work?If yes, Possible turn signal flasher burnt out, not a fuse, swap turn flasher with Hazard flasher to see if they start working.Owners manual should guide you to the flasher locations. :thumb:
93SHO'nOFF
Lehigh Valley,PA
This may be a long shot ,but if all of the fuses are ok ,I would check the wires in back of the multi-function switch.These wires can come out of the connector when using the tilt wheel .(The locking tab that holds the wire inside of connector break's) or Possibly the switch is bad ?both turn and hazard are located in the same switch. It would be easy to check,the cover comes off easily.I would take a peek at it.When you access the switch and if the connector and wires are ok ,you will need to check for power too the switch. Hopefully you won't go any further than that. :thumb:
bi0c0mp
Sh0Bi0s
Brooker,Fla
will do thanks they say there is a thing called a flasher or something to that that might of went bad so going to replace that also
