Turbocharger selected -wastegate Q.
nik97
Mile high
Hey guys. Quick question about altering a wastegate setting. First off, here's what I'm working with -Garrett/International C91 series used on the early Ford IDI 6.9/7.3 Turbo diesel engines. It has an internal wastegate with an unknown boost setting and I can only assume that it is higher than the ~5 psi I'm looking for. So here's my question, can I simply purchase a wastegate with a lower psi set spring and adapt it? I want to keep the internal wastegate on it for packaging and cost. Any ideas? Thanks.
Here's the turbocharger/wastegate.
http://i18.ebayimg.com/08/i/000/c8/4a/0cf5_1.JPG
http://i15.ebayimg.com/08/i/000/c8/4a/1e0f_1.JPG
Off Road SHO
Moderator
Cool,
I want to help! I bet you need SOMETHING that I have, and if you don't, I can get it or you don't really need it.
Tom
joshwise2003
easthampton
theres universal wastegate actuators, but sometime u need to fab the arm/mounting bracket to make it work with something custom like that, or u can take that one off altogether and hook up an electronic boost controller and control your boost from inside the car which is nice. or get an external wastegate.
nik97
Mile high
^Thanks but I'm going for cost effective. I don't want to run a remote waste gate or spend money on a boost controller when the turbo I'm using has a compapact wastegate on it. I need to know if I can change out the spring or use a wastegate with a different setting. Is this doable?
SASHO91
Zoom Zoom
San Antonio,TX
As long as the WG actuator is the same, ie same movement, same length, etc, you shouldn't have a problem. The turbo will not know the difference. I suppose the biggie here, is trying to find a WGA that fits your needs.
nik97
Mile high
Yes, I suppose I'd have to find an OE type WG that is set around 5 psi.
Off Road SHO
Moderator
Nick,
The waste gates off of the old Chrysler 2.5's were set to 5-6 PSI. That's the type I had on my old buggy (now Dusty's buggy).
Scott at Turbos Direct can probably hook you up with what you need, just take him your old one. One heck of a nice guy; he helped both Dusty and I out numerous times.
Call me for his number; he lives and works at 83rd Ave and Pinnacle peak road.
Tom
Toolman
Boost it!
Grand Lake, Oklahoma, USA
What tom said. That WGA is probably set to 20psi or something. Any idea of the A/R on that, do you have access to a compressor map?
nik97
Mile high
Tim, size wise it's a Garrett T04(305) with a cold A/R of .70 and Hot of .82. I could not find a compressor map for it. What do you make of those A/R #'s?
Tom, thanks for posting that info. Is the 2.5 the slant 4 turbo that came in all kinds of Chrysler cars? If so, Ecology salvage yard had about 50(literally) of those little suckers in the Dodge section. I think I still have Scott's # and I will probably need it eventually.;).
Eric, you are correct. The turbo is not to increase the rate of acceleration but to accelerate the rate of clutch replacement:p.
Power Surge
Palm Coast, FL
Yeah, the problem with that WG, is that you want to LOWER the boost, not raise it. I don't think you can run lower than WG boost with a controller, they are usually meant for the other way around.
As mentioned, I would try to find a factory gate off something else, that's dimensionally similar, and adapt that to your unit. Just make sure your flapper is fully closed and fully open.
nik97
Mile high
Yes, I think I'm going to go get a WG from one of the Chryslers at the yard(or a few) and see if I can modify the bracket and rod to use it on the Garrett.
Thanks guys!
