Cleaning out the garage..... AGAIN!! Lots-O-Parts!
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
here we go again.... Tom, please move to classifieds! Thanks!! :wave:
SHO Parts for sale
2010
EVERY price includes shipping.
When responding about an item, PLEASE include the item #, which is shown in each photo.
There is a photo of EVERY item. Though I did not embed every image. Look for the text links.
I have more stuff... ask me if you need something I dont have listed. Ill update with a few odds and ends as we go.
I take Paypal. [email protected]
All items will be shipped UPS ground, unless you need it faster. Then it will be shipped youre choice, on your dime.
Any questions?? Dont be afraid to ask!!
1. Low mileage 3.0 Oil pump.
Pulled from 130k mile motor.
Great oil PSI when removed.
$100 shipped
2. T-body cover. No cracks, includes bolt
$15 shipped
3. 3.0 MAF unknown condition.
$25 shipped
4. 3.0 MAFs with hoses unknown condition
$25 shipped
5. Unmodified air box, Removed from a '89 SHO
$25 Shipped
6. Weld on Stainless 02 sensor bungs
3 available.
SOLD!!
7. A set of 8each valve cover bolts. These are the primary long bolts, no small bolts included.
All of them look good, and should clean up nicely.
$25 shipped
http://www.bonnefinstudios.com/kwb/forsale/shoforum/parts04.jpg
8. T-stat housing
$30 shipped
9. Speedo cable + sensor
$25 shipped
10. Dust shield
$15 shipped
11. Starters
$25 shipped each
http://www.bonnefinstudios.com/kwb/forsale/shoforum/parts06.jpg
12. Used, grimy, but no cracks or major scratches. Should clean up nice.
Upper has a gasket, lower does not.
$25 shipped
http://www.bonnefinstudios.com/kwb/forsale/shoforum/parts07.jpg
13. Pro-M 80mm MAF with large filter and ******.
Complete with sensor and rubber boot.
$250 Shipped
14. Pair of Zirgo Brand high-flow slimline fans
Rated at 1340CFM EACH. These guys move a ton of air, and can be set up as pushers or pullers.
Wired together with an OEM gen 1 harness for plug and play.
SOLD!!!! Thanks SHOtimer!
15. Overflow tank with valve
Like new, unknown MFG.
SOLD!!!! to wjayg, thanks Jay!
16. AC compressor w/ good clutch
LOW 75k mileage. Working when removed
Stored full of ester oil, will be drained to ship.
$200 shipped
17. B9B EEC
SOLD!!
18. CCRM
$15 shipped
19. Pulled from the same low mileage '89 SHO the compressor came from.
All lines look awesome. 10 minutes with a wire brush and some paint and they will look new.
These are getting hard to find.
$120 shipped for the lot.SOLD!!!! to thegovernor9912, thanks Jordan!wjayg
20. Inner passenger axle w/ center support bearing in excellent shape.
Are these even available any more???
SOLD!!!! Thanks NP SHO!
21. Low mileage. clean Motorcraft starter
SOLD!!!! Thanks 4DR 4 SHO!
22. MTV trans mount
$25 shipped
23. Bellhousing dust shield
$15 shipped
24. Urethane STAGE 2 rear MTX rear motor mount.
Never installed.
$100 shipped SOLD!!! to .RaMpAgE.! Thanks Danny!
Added to the ***.... Nov 25 2011
26. 1989 MTX Trans 140k miles
This one came out of my daily driver. I pulled a junkyard trans, welded the diff, and swapped during a clutch job.
This trans has NO issues. No weird noises, no leaks, no surprises. Stored dry with all openings plugged with rags.
Quill sleeve is in great shape, as is the fork.
Sold as is. $400 SHIPPED
27. 1989 MTX Trans 80k miles
Came from my project SHO that got scrapped.
I have driven less than 50 miles on this trans, personally. But I see no reason why it wouldnt be 100%
It shifted great when I drove it. It turns great, with no weird noises, and no leaks. Stored dry with all openings plugged with rags.
Still has speedo cable, TOB, and cable shift brackets.
Sold as-is. $350 SHIPPED
28. And finally, Ive decided to part out my project 3.0
This is a 80k mile motor. With a good deal of bolt-ons
PLEASE LET ME KNOW IF YOU ARE INTERESTED IN THE ENTIRE THING!!
28.1
* 42# Ford racing injectors see my install page here http://www.bonnefinstudios.com/kwb/automotive/tech/injectors.htm
Id like to sell these as a package with the modified fuel rail.
Thats 6 injectors that have been cleaned, tips swapped, and tested. With a fuel rail that has been modified to fit the injectors, and tested.
Sold as is, but have my personal guarantee that they are not DOA.
SOLD!! Thanks!!
Everything else shown in the photo is for sale too.
28.2
* Urethane front motor mount. My original design that SHOSOURCE is now offering.
SOLD!!! Thanks!!
28.3
* Good OEM Motorcraft Alternator
$100 SHIPPED NO CORE NEEDED!
28.4
* Oil filter relocating kit. Everything needed/required, including custom ****** to attach to block
SOLD!! Thanks!!
And more... Coil pack, brand new AC delco plug wires, Power steering pump... etc....etc..
Just ask!!
doclees
Harrisburg pa
is your CCRM still available? If so will a G work for my 89 M? I didn't know they made a G.
Thanks
Corey
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
It is still available, though I dont know the differences between the G and the M. Didnt actually know they made different ones, until you mentioned it.
This was a stripper model though, if that helps any. No moon-roof, had manual climate controls, etc.
It did have AC.
shoon
cliTaurus
Dawson Creek, BC
DAMN! been looking for AC lines for my MTX forever. Can I steal your picture of the AC lines?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Not really.
Ive thought about it, but something in the form of a group buy would have to be done to make it worth my while.
I dont have any cores left, and Im plumb out of urethane at this point. A few gallons of urethane is pretty spendy.
.RaMpAgE.
Las Vegas, NV
np my engine moves sooo much its breaking the cooling line to the heater core lol hahah thxs for the quick reply
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Glad you got it okay!
You will NEVER have to replace that mount. The stage 2 ones are tough little buggers. ;)
As for the other items, just let me know. :salute:
.RaMpAgE.
Las Vegas, NV
I just wish i could find a reinforced front mount.... once im finished with my projectors and exhaust ill get ahold of you if you still have the stuff
markmoomnu
