2blue240
im sure this question has been asked numerous times but im trying to decide which power adder to go with. this will be in a rwd application
What kind of answer do you expect with NO details provided? They are two different systems that do the same thing, although the turbosupercharger is more efficient. A simple google will yield some very good information on turbos and superchargers. Then you can decide which will be better for your application. You say RWD, but what motor?? I assume an SHO motor....2blue240 said:im sure this question has been asked numerous times but im trying to decide which power adder to go with. this will be in a rwd application
yeah what he said, Iv found a ton of info of pros and cons on s/c and turbos on google40BelowSummer said:What kind of answer do you expect with NO details provided? They are two different systems that do the same thing, although the turbosupercharger is more efficient. A simple google will yield some very good information on turbos and superchargers. Then you can decide which will be better for your application. You say RWD, but what motor?? I assume an SHO motor....
40BelowSummer said:Well here are two questions:
Can you fabricate either system and how much room do you have to work with?
I prefer CRACK!!!!!!!!!1AREA 91 said:Coke or Pepsi
SASHO91 said:Guess you havent seen Geek SHO???
http://youtube.com/watch?v=7XvieyAIT-M
Its not a 112... but still, an M90 can put some large CFM numbers out (when properly ported, etc..)
somedude_001 said:i've always wanted to see a eaton M112 mounted on a SHO engine. I say go that route just because you would be one of the first to mount a large PD blower on this engine.
Off Road SHO said:I'm working on it. Patience, Grasshopper.
Tom
Geek SHO said:Hey, I've seen that car before!
The M90 seems to work REALLY well on the SHO motor. They're rated to spin up to 14,000 rpm. With the stock pulley, I believe the blower hits this around when the engine revs to 7000rpm.
There is SO much potential in this setup, I just don't have the time or money at the moment to really start upgrading it. Currently it's a junkyard first generation M90 that leaks oil, mounted to an aluminum box (it has the internal aerodynamics of a moving van), running on a motor with only 5 good cylinders. I'm happy with the power it made in this shape.
Despite not making a whole ton of power, the boost response was RIGHT NOW. The boost gauge looked more like a throttle gauge. Also, the sound is terrifying and incredible. I love it.
SASHO91 said:Woodlands, TX
Where abouts is that?
