TURBO OIL LINES questionsq
pitcrew207
SC'D 5.0 Right?
MD-PA
well i couldent fine much input on this subject. Looked for a good 30minutes on search.. well this is my question. Im setting up for the turbo now. where are you guys running the Feed Line from and also the return line.I thought maybe have a 3 way fitting off the Pressure sensor for the feed and return to the oil pan?? Anybody got any sites with the lines or info i could use??
thanks!
Ishodu
Sounds like you got it. A tee at the pressure sender location and and the drain line to the pan is what I have heard of people doing.
pitcrew207
SC'D 5.0 Right?
MD-PA
Thanks for the input just wanted to clarify. Figures after i post i found it in search haha :thankyou::thankyou:
