bubba
ATX Connoisseur
Is this inside of trans? and where is the BOO switch located. thanks again
TSS = Turbine Speed Sensor.
It is located just above the driver's axle on the main transmission cover.
I need a part number. The parts stores are trying to sell me a vss. I was mad and told them I would be back with a part number. Ford trying to sell me one to. Thanks for the help
Sounds like your tranny may be done.
A bad TSS will make for an erratic shift schedule and hard shifts, and a bad VSS mostly impacts shift scheduling. Starting from a stop in 1st a bad VSS shouldn't matter. You can try disconnecting the VSS altogether and see if that changes anything.
Have you tried manual 1 or 2 to see if that makes any difference?
