Trunk Opening Issue
tijas2
Boston
Recently the trunk for my 95 SHO wont open. I've tried the interior release located next to the driver's seat & got nothing. The key in the trunk itself will not turn or give any result. I also tried using the keyless entry system to unlock it only to hear the release being activated but the trunk remaining locked and closed. Anyone know what could be wrong? Thanks for the help.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
I would try pushing down (or maybe pull up) while someone else pulls the latch inside the car. I believe if its too tight, the latch will not let go of the trunk.
Cant hurt trying... :shrug:
tijas2
Boston
I believe the lever is unlocked. I tried putting the key in and turning the lock on the lever & the key would not turn. Does that mean it's unlocked?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
The key should turn in the lock no matter what...if you press the silver circle down it locks...and when you turn the key, it pops back up unlocking it.
FYI...
tijas2
Boston
The key doesnt turn for me. When I insert it, the lock can be pushed down...when i remove it, it pops back up.
tijas2
Boston
No, i'm using the circular key for the trunk...the key fits in, it just doesnt turn.
