Took the intake off of my 92 mtx and had another engine that I pulled apart and painted the intake on. Trying to reinstall and having a **** of a time getting it to bolt up to the engine. seems to be a little tight, even with new gaskets installed. This is my second attempt and I'm starting to get ******! Seems like it should be easier than this! I thought about loosening the rubber runner connections, but it's really the bolted connections to the secondaries that stiffen the whole assembly it seems, and you can't tighten the lower bolts once the intake is on! Please give a brother a hint... Going nuts!
