TReplaced power antenna mast, now new problem
Jr's Sho
Moss Point, MS
Okay, so a couple of weeks ago the mast on my car broke. But I had a spare antenna which had a bad motor so I pulled the mast from my spare antenna and put it on my SHO tonight. I had my friend turn the car off while the motor grabbed the mast cable and the antenna began to retract. Once it bottomed out, there was still some antenna up. So I tightened the 14mm nut up and turned the car on and the antenna extended way too far up, it is now loose and can be wiggled while it's up. I don't know what happened, the teeth are meshed together with the motor and the two nuts are tight. Any ideas?
