dranniK
Well on Monday I was just driving and while coming to a stop at a light the car felt like it shifted down when I was at a complete stop. Light turns green and I try to take off and the car starts to rev while I'm in drive. Eventually I toss it into reverse and back into drive and it takes off. Down the road I feel this soft kick feeling and the car starts revving again. I pull over and check the tranny fluid and the level is fine and it's still red, so I get it towed to a shop. I can still move the car but I have to put it in park and restart the car, then a few seconds later it will act up again after I take off.
I had the mechanic add some lucas tranny fix in it, he says that it won't even stay in gear now. The first stop-light situation happened a month or so prior where it sat in drive and revved but after a second or so or revving the car put itself back into drive and I could take off, that was the only time the car did this and didn't happen again until Monday.
What am I looking at, tranny re-build or is there some other under-lying problem that I don't know about? Thanks for any insight.
Also, I take it the AX4N from a v6 will fit with the SHO so long as it's a 96-97 correct?
