Yoon
Hello,
1990 SHO, 95K, is giving me problems and making me frustrated. All I ask here is for opinions and diagnoses. Here goes....Firstly, (this does not bother me but could help with diagnosis)...clicking noise coming from clutch area, but goes away when light pressure is applied. When gas is given, clicking/rattling progressively speeds up with engine speed. Now, this is what is so frustrating...Shifting is very very very stiff. Sometimes it even grinds. Reverse always grinds badly. Downshifting never results in a grind- only on the upshifts. Also, at idle, just sitting when parked, shifting through the gears is near impossible. Clutch grabs fine and the auto adjust stated in the manual does not fix things much. Questions...can a tranny flush and fill remedy anything? By the way, tranny fluid is full to the fill plug. Will a clutch job fix these problems, or is it synchros(please no)? What should I do?...Is there ANYTHING I can check before dropping hundreds of dollars into the car? Please reply because just driving the car makes me really mad as a result of the shifting. I want to ask here because of the experience present. Shops seem to MISdiagnose SHOs often.
Thank you for your time.
-Robert
-Robert
