pitbull
SHOmanyproblems
My transmission died today. I am wondering what you recommend when having them rebuilt to make them more reliable/better/performance wise etc.. Know of any good kits to use? Thanks!
pitbull said:My car was driving fine down the road, at about 140km/hr.. I was doing this for about 10 minutes when all power was lost. I pulled over, and the car didn't want to go anywhere fast, it felt like it was in a "limp mode".. I let it cool down for about 20 min, then it drove fine. I drove for about another 45 minutes when the same thing happened again, so I tried letting it cool. It didn't work this time, The car refuses to do anything over 10 km/hr, its not slipping, the RPM won't go above 1500 while in gear.. Sometimes it would stall the car out after driving this slow for a minute or two.. Any ideas? Also, I hear a loud hissing/blowing sound outside the car
pitbull said:Yes the cams are welded.. turns out it was the 3rd cat and flex pipe had imploded and plugged (possibly due to the horrible missfire when I first got the car)[/QUOTE
good thing I got rid of my 3rd kitty already lol... My old jeep did that except I looked under and the catalytic converter was glowing red hot.... just be glad that your trans is ok and you had a good reason to cut off the 3rd cat!![]()
Mcloud1 said:I think with you install the new one you should install a transmission cooler, a must for any Taurus.
say something we don't know...YAHTEC said:say something we don't know...
Porkchop said:Transgo shift kit, backdate the pump shaft seals to 1 piece, update the pumpshaft to a high-flow pumpshaft (sometimes referred to HD pump shaft) and weld the low speed drum to prevent separation.
Thats to name a few.
