Transmission ? 92
KM92SHO
Burrillville R.I.
Ok i blew my transmission in my 92 MTX and i got a new one from a 89. now i believe the 92 is a rod shifter but the 89 is cable right. there wont be a problem with that right the shop can still keep and rod shift right
TYSHO
Earth
From what I'm looking at, it should. At least I hope it does, because I'm doing the same as you but vise versa.
projectSHO89
SHOless In St L
There is no difference in the transmissions (rod vs cable shifter). All the MTX trannys are identical from the factory for 89-95 as far as this is concerned.
Steve
Bizzy
To further elaborate on Steve's response, you'll have to remove the cable shifter bracket from the tranny in order to use it with a rod shifter. No biggie, just a few bolts.
KM92SHO
Burrillville R.I.
Ok thats good to know because i got a transmission out of a 89 and i think its cable shift and i have a 92 that i believe is rod shift.
