LeeSHO said:i'm not good with any fuses, which one am i looking for?
From the Ford manual:
1. NOTE: Locking tab must be lifted before connector can be removed.
Disconnect the wire harness at connector from the stoplight switch (13480).
2. NOTE: Since the stoplight switch side plate nearest the brake pedal (2455) is slotted, it is not necessary to remove the brake master cylinder push rod black bushing and one white spacer washer nearest the pedal arm from the brake pedal pin.
Remove hairpin retainer and white nylon washer. Slide stoplight switch and push rod away from pedal. Remove stoplight switch by sliding switch up/down.
INSTALLATION:
1. Position stoplight switch so that U-shaped side is nearest pedal and directly over/under pin. The black bushing must be in position in push rod eyelet with washer face on side away from brake pedal arm.
2. CAUTION: Do not substitute other types of pin retainers. Replace only with production hairpin retainer. Damage to components may occur.
Slide stoplight switch up/down trapping master cylinder push rod and black bushing between stoplight switch side plates. Push stoplight switch and push rod assembly firmly toward brake pedal arm. Assemble outside white plastic washer to pin. Install hairpin retainer to trap whole assembly.
3. NOTE: Stoplight switch wire harness must have sufficient length to travel with stoplight switch during full stroke at pedal. If wire length is insufficient, reroute harness or service as required.
Assemble wire harness connector to stoplight switch.
4. Check stoplight switch for proper operation. Stoplights should illuminate with less than 27 N (6 lbs) applied to brake pedal at pad.
Also, as far as ATF goes, Valvoline Max Life seems to, uh, mesh well with the tranny, and it's fairly cheap. Some people go with the Mobil 1 ATF but my god, is that stuff expensive.
