6SHOoter
Need to replace the top line from the radiator to the trans cooler. Does anyone know of an aftermarket replacement that will work or is it time to hit the junkyards?
Trans re-plumb completed; Driving at 80mph on the freeway on a 94 degree day for 25 minutes while testing trans-temp = 168 deg.
Thanks for the ideas & input!
Next problem: I need a new IMRC solenoid! Any ideas?
I need to find a code reader that's compatible. period. not into counting blinks.
