trans? diff? clutch?
mattsho1993
SHO owner
albion, new york
Ok i bought a donor trans last year replaced seals fresh fluid. I installed it, I backed out of the drive way put it in first it grinded slightly. Figured for some reason it did it above 10mph if i was below 10mph it wouldn't grind. other than that no problems at all besides a balljoint problem. 1k later I was coming home from the store it was in neutral and i was braking to a stop sign at about 60... i felt a wobble in the front end as if the brake caliper or rotor was about to break. I stop at the stop sign get out look no visible problem, I get back in and there is no gears it goes in and out of gear no problem but there is no transmission, there was no clunk no bang just the wobble? Its winter now and i took it off the road gonna save up money and start buying everything, new clutch, try and find a low mile trans, weld diff etc. etc..... but what do you guys think?
:munch:
93rev2sev
Hockeytown
That's as good a guess as I can think of. You'll just have to get it up on stands and have a look.
mattsho1993
SHO owner
albion, new york
If it was the wheel bearing couldn't i jack it up and put it in gear and see if the axle spins? The first thing i checked was the axle coming out of the trans.... What else if i dont see the axles spin?
