tardboy21
I recently got a 99 and have a little annoyance when riding down the highway. Shifting through the gears seems to be ok under normal acceleration, but when cruising at any speed, every 10 seconds (give or take) it feels like the torque converter will start to unlock and then lock again. The rpms will rise about 150 and then go back down again. If I stay slightly picking up speed, it usually does not unlock.
Also, under slow acceleration it feels like the it may lock to early.
Fluid smelled fine, but as a precaution I put a tranny cooler on it (6 row) right away. I put a tad bit more tranny fluid in it and it is at the proper level. The amount of fluid I added did not seem like it would fill the tranny cooler lines and the little bit lost disconnecting the lines. Could there be an air bubble stuck in there? Would running to cold cause this?
I had only driven the car twice before this, and would not be able to say for certain that it was not already like this since the rise in RPMs is so slight. Any ideas or experiences that may help?
