tranny go bang :(
mattsho1993
SHO owner
albion, new york
ok so i was driving the other day in a straight line got on it a bit no spin got to 55 and tranny went bang. looked behind me gear oil and oil ******* and burning out the back. do a u turn head home and axle clunks and bangs locks up tire. replaced axle stil;l doing it obviously i need to replace the rear main and trans seals but whats with the axle bang it will literally lock my tire and steering wheel.????????????????????????????????????????????? HELP should i start looking for a tranny :busted:
frosho
WOLFMAN
Tyngsboro, MA
This is an MTX, correct? It sounds like you joined the prestigious blown differential club.
Racer X
SHO Pilot, Retired
Connecticut
Why was it necessary to spam up the boards with this?
One post in one forum would've gotten you the same discussion.
mattsho1993
SHO owner
albion, new york
for your info i accidentally put it in the v-8 one so i moved it to this one! whats unnecessary is your attitude!!! were all here to help each other not be harassed by people! so have a nice day x
AREA 91
PA SHO SHOP
Area 91
Sounds like you need a new tranny WITH a reinforced diff so it dosen't happen again.
Been there, done that.
My Daily driver has a reinforced diff that I welded myself, and my nasty plus has a quaife.
You gotta pay to play with these cars. A Quaife or Wavetrack may seem expensive at first, until you blow a tranny. Now you need to find a used tranny and swap it in. Chances are that you may have gotten atf fluid on the clutch when the diff shot apart. This means you need a clutch as well!
Used MTX $350
Stock clutch kit $325
R & R the trans $500
Get's expensive quick!!!
mattsho1993
SHO owner
albion, new york
ok so you know the tranny go bang upon inspection i noticed a giant crack going from the rear of the tranny where the shifter bolts on up :( wtf coulda caused that i have pictures but dont know how or where to post
sho4life
midwest
That is probably from hard shifting. Do you have solid mounts or bushings. Someone on here custom makes a rod shifter boss brace. who is it?
NOTAURIUS
PA SHO SHOP
From hard shifting?! It's more like excessive wheel spin and about 150,000 miles without changing roll pins or trans fluid
tinkerkathleen
