Tranny Fluid?
MilTownSHO
Horicon, WI
I'm 99% sure that 98 and up takes Mercon V fluid but the manual says differently. So to make sure I thought I would ask:
Does the 98 SHO tranny take Mercon V or regular Mercon III? shrug
ES96SHO
SHOtime96
West Lawn, PA
Is there a reason why the 96 & 7 don't use the synthetic? From everything else I've heard, there are not other differences.... Would it be a problem to run the MerconV in a 96?
George
There must be some reason. Clutch material maybe? If you want a synthetic ATX there are several out there that will cover both Mercon III and V specs.
David Carpenter
