Tranny dead away from home.
TheScaryOne
So I was driving, and I think I lost second gear. My ABS light came on and the car started acting very erratically, giving it gas but no go. I think my tranny is fried (AX4S), and I've gleaned some information about a rebuild from searching. This car isn't destined for performance, just a high-performance daily driver. So I figure I'd need
S86165B - Superior **** Dam Kit
And either the Superior shift correction kit or Transgo shift kit. I've used B&M on my Camaro, and regret the choice, so I won't think of touching them on this tranny.
I'd also like Kolene Steels and Kevlar clutches, but I figure I can tell the rebuild shop that and have them source them.
Is there anything else I should get myself before letting a shop work on my car? Most people recommend the TC from SHO source, but is this that big of a deal on a car that won't see beyond stock engine power? Is there anything I should tell a shop I want done specifically? How much should I be looking at for a rebuild?
Also, can the AX4N be swapped in? Some people say yes, it's easy, and all you need to do is swap a few parts, and then other people say it's impossible because of the bolt patterns. That makes no sense.
:thankyou: for any help!
bubba
ATX Connoisseur
Fort Wayne, Indiana
the v8 no....but with enough money anything can be swapped in... But rebuilding this transmission isn't cheap to rebuild at all though. 1800 give a take a 100 or so. But sounds like you broke a hard part
TheScaryOne
I thought so too. Until I got in the car later, started it, and it drove up and down the street just fine. >.< Going in for a diagnostic tomorrow.
The transmission has been leaking fluid, but every time I check the fluid, it's always at the full mark on the dipstick, no matter how many times I wipe it off and recheck. I'm beginning to think it's my rack leaking and someone just filled it with ATF.
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah, you can use, transmission fluid in your power steering..... I would double check it though, hard parts in the trans... don't show up fulltime until they break. That's what happened to me lol
AREA 91
PA SHO SHOP
Area 91
89-95 sho's use ATF in the power steering system.
TheScaryOne
Ah, so it was factory. I know you can swap the fluids (unless you have a Hon-DUH, where you need their special fluid) and if I ever change the rack I'll flush it and fill it up with power steering fluid just because I like the color difference.
So it should be about $1800? The quote I got from a local shop was 18-2300, and they did a good job on my last transmission, so I figure I'll go with them if my diagnostic comes up that the transmission needs a rebuild.
So, get a shift kit, the **** dam, kevlar friction plates, kolene steels, and replace the aluminum input drum with a steel one?
Edit: And all new electronics in the tranny, don't want them to go bad and have to tear it all apart again.
Anyone else recommend anything else? There's a thread on here that I don't have access to that is supposed to talk about a lot of transmission upgrades, which seems to be the case with most of the old useful threads. :/
bubba
ATX Connoisseur
Fort Wayne, Indiana
That sounds about right on the qoute! or if you want one **** of a trans PM sho#7 he is a mad man about these transmissions.... so I've heard
TheScaryOne
So, the dealer test-drove the car, had no codes, and checked all of the pressures. All normal. Fluid looked clean, proper level. :/
I drove it around after that beating on it, to see if I could get it to happen again, and it wouldn't. Crossing my fingers and hoping it was a fluke.
SolidState
No Mo SHO
Toronto, Ontario, Canada
sounds like an issue with the hydraulic controls.
My old 94 ATX had a scoured valve and bore in the valve body causing erratic valve movement. The car exhibited some very odd shift characteristics at times.
Unfortunately, it required a new valve body and the mating plate (name escapes me at the moment).
