masho95
got Zex?
I'm having some problems getting the shifter in gear from a stop. Once in gear it will smoothly shift between gears. From a stop with the foot off the clutch it's really hard to gear into almost every gear, but it will usually get into 2nd and 4th the easiest, so from there I go into 1st.
There's a few months worth of driving on the new clutch, and I had topped off the tranny with some Mobil 1 Synthetic ATF. So I'm trying to narrow down the problem now as it seems to be getting slightly worse over time. I need to recheck the tranny fluid to make sure it's full though.
I also have a Jose SHOrt shifter, and pretty sure everything is back together right. One night a while ago it was freezing out and I couldn't get it into any gear for quite a while when I went to start up the car, I mean with the clutch fully pressed in I couldn't even jam it hard to any gear. Any suggestions on what to check. I mean getting it hard into any gear is that a sign of a clutch issue, shift linkage, tranny fluid, etc. I have to change the oil very soon so when I'm under there I'll double check that everything is tight and in place. Thanks!
